PRBS for GTX of kintex-7 FPGA
In the GTX IP configuration, I can choose to use the PRBS generator and checker. But I do not know how to send PRBS from TX port and received through RX port.
In my board TX and RX of the same channel are connected on board in AC coupled way. I create the example project by right clicking the GTX IP and choose open example project. There is PRBS selection port in the IP. My experiment shows if I select PRBS to PRBS-31 or other. The IP does not send the  PRBS data to the TX port. It still accept data sending to the txdata_in port. And I can verified that by the received data from RX port (after unscrambling). How to make TX send PRBS? I also wondering why the PRBS always exists in the ports list of the wrapped GTX IP, no matter I choose to use the PRBS generator and checker or not.
Thank you
I would suggest simulating the example design and looking into the design schmatic to make sure the prbs selection bits are making it all the way to the GT*_CHANNEL.  If the bits are selected it should affect the output.  There may be an exception if you are using the GEARBOX in your design. Is this the case?
I am indeed using gearbox, what does it cause?
I have verified by checking schematic and chipscope that selection bits are making it all the way to the GT*_CHANNEL.
Please attach the *.xci file for your design and I can take a look.
I have verified the problem occurs because of I only set the selection bit of rx, not tx.
