Participant add_engineering
PS-GTR Eyescan
On the GTH-transceivers of the UltraScale MPSoc it is possible to perform an eyescan of the tx/rx path. The UltraScale MPSoc however also has PS-GTR transceivers. What is the approach to performing an eyescan on the PS-GTR transceivers of the UltraScale MPSoc?
Ed
Re: PS-GTR Eyescan
GTH eyescan can be done manually, or using the IBERT core. AR 67295 is a walk through of the manual flow. UG908 has an explanation of IBERT. GTR is a bit different, it will have an eyescan core released in a future version of the tools.
Re: PS-GTR Eyescan
For more information about PS-GTR debug, please contact your Xilinx technical sales team.
Visitor jarnwine
Re: PS-GTR Eyescan
Is there any new information on the Zynq GTR IBERT and Eyescan?? I have seen UG908 and UG936, Is there anything else?
回复: PS-GTR Eyescan
hi @add_engineering
for GTR eye scan, you can refer to UG936 chapter 10 (page 175 - 211)
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug936-vivado-tutorial-programming-debugging.pdf
Boris
Re: PS-GTR Eyescan
hi @jarnwine
yeah, that's what we have.
thanks,
Boris
回复: PS-GTR Eyescan
Hi Boris,
We have contacted Xilinx in 2017 and we have tested this with the Engineering Samples of the MPSoC.
Visitor jarnwine
回复: PS-GTR Eyescan
We have successfully used UG936 lab 10 to create the eyescan tests for our custom card.  It turned out we needed to use the downloadable  FSBL generation script to create the eyescan FSBL  elf file. So our problem was resolved.
Observer electrodev99
回复: PS-GTR Eyescan
The Lab10 tutorial acts as if you will only be doing eyescan/IBERT for USB 3.0, are there any changes to made to the xsct_create_fsbl.tcl to use 4x PCIe instead? I'm confused by this.
回复: PS-GTR Eyescan
Quick update on this -- I was wrong. The USB 3.0 stuff is just a quick fix to ensure that USB comes up if there is a USB 3.0 device on the transceivers. As far as I know, PCIe doesn't need any workarounds to come up.
