avinashc
Place:1073 - Placer was unable to create RPM[GTP_RPMs] ---- for Spartan 6
I am getting this error in mapping:
Do I need to add something in ucf?
What can be the issue here?
ERROR:Place:1073 - Placer was unable to create RPM[GTP_RPMs] for the component
   aurora_module_i/gtp_wrapper_i/GTP_TILE_INST/gtpa1_dual_i of type GTP_DUAL for
   the following reason.
   The reason for this issue:
   All of the logic associated with this structure is locked and the relative
   placement of the logic violates the structure. The problem was found between
   the relative placement of GTP_DUAL
   aurora_module_i/gtp_wrapper_i/GTP_TILE_INST/gtpa1_dual_i at site
   GTPA1_DUAL_X0Y1 and IPAD RXN at site IPAD_X1Y9.  The following components are
   part of this structure:
   GTPA1_DUAL_X0Y1 and IPAD RXP at site IPAD_X1Y11.  The following components
   are part of this structure:
   GTPA1_DUAL_X0Y1 and OPAD TXN at site OPAD_X1Y6.  The following components are
   GTPA1_DUAL_X0Y1 and OPAD TXP at site OPAD_X1Y4.  The following components are
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Thanks!
roym
I havent worked with spartan in a long time but It looks like you had the gt wizard place the gtp in one location and then tried to move it with the IO loc?  You should only place the gtp in the wizard.  You shouldn't need to loc the RXP at all.  Could this be the problem?
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
