rikraf
Problem with IBUFDS_GTE4 on VCU128
Hello all,
I am working on a VCU128 design employing the GTY transceivers, and I'm stuck at a very basic thing: the IBUFDS_GTE4 seems not to be working.
To see the very basic functionality of the buffer, I've implemented a toggle FF driven by the ref_clk, via IBUFDS_GTE4 and a BUF_GT.  Here's the HDL:
wire gty_refclk;
wire gty_refclk_int;
IBUFDS_GTE4 #(
.REFCLK_EN_TX_PATH(1'b0), // Refer to Transceiver User Guide
.REFCLK_HROW_CK_SEL(2'b00), // Refer to Transceiver User Guide
.REFCLK_ICNTL_RX(2'b00) // Refer to Transceiver User Guide
IBUFDS_GTE4_0 (
.O(gty_refclk), // 1-bit output: Refer to Transceiver User Guide
.ODIV2(gty_refclk_int), // 1-bit output: Refer to Transceiver User Guide
.CEB(1'b0), // 1-bit input: Refer to Transceiver User Guide
.I(refclk_p), // 1-bit input: Refer to Transceiver User Guide
.IB(refclk_n) // 1-bit input: Refer to Transceiver User Guide
wire gty_refclk_int_buf;
BUFG_GT BUFG_GT_REFCLK (
.O(gty_refclk_int_buf), // 1-bit output: Buffer
.CE(1'b1), // 1-bit input: Buffer enable
.CEMASK(1'b0), // 1-bit input: CE Mask
.CLR(1'b0), // 1-bit input: Asynchronous clear
.CLRMASK(1'b0), // 1-bit input: CLR Mask
.DIV(3'b000), // 3-bit input: Dynamic divide Value
.I(gty_refclk_int) // 1-bit input: Buffer
reg testflop = 0;
always @(posedge gty_refclk_int_buf) testflop <= !testflop;
assign test_out = testflop;
And here is the implemented design:
The input is about 800mvpp differential at 500MHz; on the VCU128 this pair is ac-coupled into AN40/AN41.  Probing the coupling caps I can see the signal, and I can also see the 900mv bias voltage (MGTAVCC) on the FPGA side of those caps.  But test_out is not toggling.
In simulation, the proper 250MHz output is produced.  I've tried a lower frequency in case there were signal integrity problems with my source (though the differential signal looks fine).
The only mystery about the implementation is about the value for REFCLK_INCTL_RX (= 00).  UG578 says to "use the recommended value from the WIzard", but I don't see any Wizard which generates code for the IBUFDS_GTE4 (my Wizard-generated GTY core resulted in a single-ended refclk input; I had to put the IBUFDS_GTE4 in myself).
One input, one output, one filp-flop; doesn't work.  What am I doing wrong?
rikraf
Thanks for your help, the problem was in my understanding of the "Vitis" tool, which was new to me.  In fact my bitfile had never been updated, so I was programming the FPGA with the old design which didn't have the BUFG_GT or toggle FF at all.
The design has a MicroBlaze processor, to set up a few peripherals needed to generate the off-board clock.  In SDK, I was used to "exporting the hardware with bitstream" and then recompiling.  In Vitis it seems you need to also do a "clean all" to get the new bitfile in there.
Now my 500MHz refclk does produce the 250MHz at the testpoint.
Thanks again
Rick
eschidl
Hi @rikraf ,
I do not see an immediate error in your setup. To get the IBUFDS_GTE example generate the example design of the core you created. It should then be placed in the toplevel there.
How do you observe the FF? external on a pin or with ILA? You could also implement a counter on the clock and observe the counter value in the ILA. ILA would only rely on internal signals. You could run the ILA on a system clock of the board. It would not need to be cycle true here.
Maybe try another quad, like 131, where you have an onboard clock coming in.
rikraf
Thanks for the reply.  I observe the test_out signal on an external pin.  I can try with ILA, too.
When I generated the example design it also had a single-ended refclk input.  I will try that again, maybe I misuderstood something.
Am I correct in setting both CEMASK and CLRMASK to 0 on the BUFG_GT?
I'll try the onboard clock, good idea.
Rick
eschidl
Hi @rikraf ,
just reduce the BUFG_GT instantiation to this:
The SW will do the rest.
rikraf
Thanks again
Rick
