ytlai
Problem with ultrascale GTY 8B/10B with 5Gbps
I am testing the ultrascale GTY 8B/10B with 5Gbps. FPGA is xcvu080.
By using the IP core, I have tried both qpll0 and cpll.
(By checking ug578, cpll is recommended under 5 Gbps.)
The data from TX is fixed as 16'h00BC, and tx_ctrl2 (tx_charisk) is set a 0'b00000001.
In this setup, RX should receive the same pattern and charisk is the same position.
But the data from RX looks totally crashed.
Here are some of the points that I have confirmed:
- Data path width is 16 bits, so userclk is ~250 MHz.
userclk for both TX and RX are generated with correct frequency.
gtwiz_userclk_tx_active and gtwiz_userclk_rx_active are both 1.
- rxcommadeten, rxmcommaalignen, and rxpcommaalighen are set to 0 by default.
- tx8b10ben and rx8b10ben are set to 0 by default.
- rxvalid port is all 0.
- cplllock is 1.
- cpllfbclklost and cpllrefclklost are both 1.
- All the resetdone, tx_done, rx_done are 1.
In summary, it is in clklost state (cpll is locked) and rxvalid is not ready.
I also tried to use cpllreset and gtwiz_reset_all to recover, but the situation is still the same.
Is there anyone know how to improve it or there is anything I missed to setup?
Thank you.
ytlai
I found the solution. The setup below should be used:
rxcommadeten = 1
rxmcommaalignen = 1
rxpcommaalignen = 1
rxslide = 0
Then, the data from RX is correct.
roym
Don't all of these need to be set to 1 for comma alignment to work?  Does the example design simulate properly?
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
ytlai
Thank you pointing it out.
As far as I know, commaalignen and commadeten have to be set as 0, which means comma alignment is enabled. It is the same as in virtex 6 GTH and GTX (0 means enabled).
Also, tx8b10ben and rx8b10bin are both 1 actually. Sorry for the typos in original text.
ytlai
I checked the user guide again and I found the recommended way:
rxcommadeten = 1
rxmcommaalignen = 0
rxpcommaalignen = 0
rxslide = 0
Also, virtex 6 uses the same setup as above.
However, the RX data is still crashed.
ytlai
rxcommadeten = 1
rxmcommaalignen = 1
rxpcommaalignen = 1
rxslide = 0
