Python interfacing for IBERT design
I am using the AVNET board. FPGA is programmed with IBERT design. But I need to save the data for a long time. Is there any python script interface with vivado processor? If so, please suggest me an idea.
Hi @vilashini ,
there is no direct interface for Python to Vivado so that you could run Vivado commands directly in Python.
Vivado is controlled through a Tcl interface.
All Vivado user commands are given as Tcl commands. So the input for scripting would be the Vivado Tcl console or the Vivado Tcl shell.
What you could do is to call the Vivado Tcl shell from Python in batch mode, but it is still Tcl running underneath.
proc write_xadc {i} {
        set systemTime [clock seconds]
        puts -nonewline [clock format $systemTime -format %H:%M:%S]
    puts "  $i"
    flush stdout
proc do {end_time} {
    set end 0
    while {$end < $end_time} {
        after 1000
               write_xadc [get_property RX_BER [get_hw_sio_links]]
        incr end
do 10
I have used the above coding. Data is printing in the Tcl console. But, I want to log the data in the .txt or .csv file. Can you please suggest to me?
hi @vilashini ,
the 'puts' command allows a file descriptor to print to. Please check with the standard Tcl documentation.
You need to open a file for writing first.
e.g.
set fileid [open <./blah> w]
puts $fileid "some text"
        set fp [open “myfile.txt” w+]
        puts $fp “$i”
        close $fp
    flush stdout
The file is opening in the folder. But, I need to print the timestamp and data into the file continuously. How will I do?
    set end 0
        after 1000
        incr end
do 10
        puts $fp “[clock format $systemTime -format %H:%M:%S]”
        puts $fp “ $i”
       close $fp
This command is printing into the file only once. How will i log the data continuously?
hi @vilashini ,
open the file before the 'while' and close it after.
Give the file ID as an additional parameter to the procedure write_xadc.
proc write_xadc {i,fp} {
        puts $fp “ $i”
    flush stdout
    set end 0
        after 1000
               write_xadc [get_property RX_BER [get_hw_sio_links], get_property myfile [get_files]]
        incr end
       close $fp
do 10
I am getting an error showing "Too many positional options when parsing"
Please suggest me the commands for passing the file name, since I am new to vivado.
proc write_xadc {end_time} {
        set filename C:/Users/Vilashini/Desktop/XADC_dump.csv
        set fileId [open $filename "w"]
        set end 0
               after 1000
               puts -nonewline $fileId [clock format $systemTime -format %H:%M:%S]
               puts -nonewline $fileId ","
               puts -nonewline $fileId [get_property RX_BER [get_hw_sio_links]]
               puts -nonewline $fileId " "
               flush stdout
        incr end
        close $fileId
If I execute this above program, the file is not been created and also values have not been logged into the file.
        set filename C:/Users/Moorthi/Desktop/XADC_dump.csv
        set fileId [open $filename “w”]
        set end 0
               after 1000
               puts $fileId " "
               flush stdout
        incr end
        close $fileId
write_xadc 10
I have executed this program. Successfully loaded the values into the file. But if I run the loop 10 times, the same value is loading. Values are not changing
You can used this code for IBERT desgn :
# sms.py: class SmsClient: def __init__(self, url, username, password): self.username = username self.password = password def send_sms(phone_number, message): # TODO - write code to send sms pass
Will sms pass helps in logging the real-time data?
Hi @vilashini ,
what values are not changing? time or RX_BER? or both?
RX_BER
Hi @vilashini ,
do you see the value changing in the GUI?
When I run the Tcl script GUI values also not changing.
But when I stop the Tcl script, RX_BER values are changing in GUI.
Please can you suggest me the solution?
To use Vivado form python I suggest to use pexpect or wexpect.
To start you can view my cleye project, which is under development, but to goal is to give a handy python wrapper for IBERT, to make the eye more clean, and open.
Hi @vilashini ,
it looks like you are running into the situation that calling your script is seen as a single running command and preventing the IBERT GUI to update values in the mean time. I am not aware of a way to work around this right now. Maybe if you put your script into the background.
Might be that the solution @betontalpfa is recommending would be a better approach here.
As a hint for @betontalpfa , for link tuning exist the bundle of xapp1295/xapp1322, which might interest you and maybe you can add this to your eye cleaner.
Do we know the transmitted pattern. Iam generating PRBS- 7 bit. How do we know the sequence of binary data?
Take a look at this document (p. 148; chapter: TX Pattern Generator)
Can we compare the Tx pattern and Rx pattern and calculate the ber manually?
I am generating PRBS 7 bit polynomial. How do we know the transmitted binary pattern sequence from the polynomial? What are the seed values chosen?
Hi @vilashini
Note, that the JTAG/TCL much more slower than a transceiver, so it seems (if I understand correctly), that theoretically impossibile to set/store the pattenrs on the fly. What is your usecase? Why do you interested in this?
I am going to use it for free space optical communication, where the receiver and transmitter are located on different buildings. So I can't able to loop back the receiver to same FPGA board. So, I manually need to calculate the ber by knowing the TX and RX Pattern.
I see.
Shortly:
You dont need to calculate BERT manually, you can use any protocol and the FPGA will calculate the BERT automaticly.
Detail:
Please take a look on the UG476 Transceiver Guide, (RX Margin section). If you understand the structure of the BERT calculation, it does not requiresto know what data is sent over the link
Maybe this post can help you too, where I learnt the same.
Sum:
  1. Load an image containing an IBERT in the FPGA on the both side of the link.
  2. Add manually links in IBERT's GUI in the hardware manager
  3. Set the same pattern on both side (then reset the link. )
  4. You should see link up, with no BERT.
Note, that if you dont use the same pattern the BERT will be calculated correctly, just the GUI will report no link.
  1. Load an image containing an IBERT in the FPGA on both side of the link.
                             Do we have to use two FPGA Boards?
You mention that you have two boards in two buildings...
I didn't get the question...
The IBERT module itself does not requires two boards or FPGAs. The endpoints of the link under scope can be in the same FPGA, or in different FPGAs on the same board / same JTAG chain or on different boards / different JTAG chains.
