Newbie sreevm96
RMS jitter value of XCZU19EG
I am working on  XCZU19EG-2FFVD1760E. I did'nt get the value of RMS jitter of the transciever clock from the documents. Please share RMS jitter maximum value.
Re: RMS jitter value of XCZU19EG
We use a phase noise plot to specify the "jitter" component that is allowed.  This is because not all jitter frequencies will be a problem for the GT so that using phase noise may allow the use of a cheaper oscillator.  There are some online phase noise plot to jitter converters that you might use to get a ballpark for what the jitter should be.  You should also be able to get phase noise information from oscillator vendors.
The clock reference clock requirements are defined as a phase noise mask.
GTR is table 61
GTH is table 102
GTY is table 114
http://www.xilinx.com/support/documentation/data_sheets/ds925-zynq-ultrascale-plus.pdf
Newbie sreevm96
Ok. Got it. Thank you for the explanations.
