matth32
RX termination voltage used in IBIS-AMI model
I would like to know if we can set the RX termination voltage on the IBIS-AMI model of Zynq US+ and Zynq7000  or if the model use ony differential termination and not the common mode voltage?
jhua
Hi @matth32
In the IBIS-AMI simulation only the differential signal is simulated and there is no way to set the RX termination bias.
Jessica
If starting with Versal take a look at our Versal Design Process Hub and our
Versal Blogs
