Visitor levinson
Re: Transceiver DC Balance
Actually scramblers do NOT have DC balance. Their disparity is theoreticall unbounded. The 64b/67b Interlaken prototcol uses the 67th bit to indicate that the frame is inverted. In this way it keeps the disparity bounded.
How does the DC balance work for the 64/66?  What I see on this is that it is theoretically unbalanced and can also give long run lengths that would violate specs but these events are "statisically bounded" making problems very unlikely.
Advisor evgenis1
Advisor
Hi @roym ,
Attached is an excerpt of how it works in PCI Express usng 128/130b encoding. In short, it's the responsibility of a transmitter to keep track of a proper DC balance, and send specially formatted packets to reduce the imbalance.
Evgeni
Tags (2)
Scholar drjohnsmith
Quick word.
8:10 encoding et all , have two codes for every symbol,
these are good for generating lots of clock frequency, and is easy to encode / decode, but one has a slight positive dc bias, one has a slight negative dc bias.
As said above, the transmitter switches which of the two codes to send for every symbol to keep the DC offset 'zeroed'.
