lumianic
SI Simulation Example AR#66160
I download the work file and open in ADS2018. The work file has missing S-parameter file and ibis model.
The application engineer name is Srinadh according to the file path. can someone provide me the missing file?
Tags (3)
venkata
Hi @lumianic
Have you downloaded the IBIS-AMI models of UltraScale GTY from the lounge? --  https://www.xilinx.com/member/ultrascale_ibis_ami.html
S-parameter file and ibis model should be available in the package downloaded from the lounge.
