Visitor batowe
SPDIF RX IP not working on Basys 3
Hi, I am attempting to implement an S/PDIF IP receiver on a Basys 3 development board as part of a degree research project and am encountering some problems which I could really do with some help with.
Essentially, I cannot get the SPDIF to output anything, either in RX or TX mode. I have built a hardware SPDIF to logic level converter on a separate PCB to capture the source SPDIF coaxial signal and have verified that this is working correctly and being input to the Basys 3 board (a positive edge on the coaxial signal produces a positive 3.3v logic edge on the Basys board, verified by feeding this back out through another header pin). My SPDIF signal is coming from a Windows PC and is verified OK (it works if input to a DAC). I am certain that my converter is not dropping any bits (have analysed on an oscilloscope and it works faithfully).
I have tried all manner of clock combinations (the master clock is the Basys' 100MHz master, which I have verified is working correctly) and reset sources, but nothing will make the receiver output any data. Same with the resets, nothing works no matter whether I feed them through a master reset IP module, switches or constant sources.
My questions:
Do I need to connect an AXI4_LITE bus even if I just want to perform passthrough to another stream interface?
IS it OK to provide the rx module an SPDIF from an arbitrary I/O pin or does it need to be a particular type of bus?
I am presuming that the rx module should generate an rxclk as long as it sees a valid input?
Is my SPDIF conversion correct (i.e. a positive edge on the coax generates a positive edge on the logic and vice-versa)?
Does anybody have a working block diagram topology that they would be willing to share?
Many thanks for any suggestions.
Visitor batowe
Re: SPDIF RX IP not working on Basys 3
Worked it out. I wasn't configuring the module correctly at startup. Solved with a JTAG to AXI master to perform register configuration. Perseverence and a sharp learning curve!
