Visitor dawang
Serial I/O Scan status reports incomplete, where the link is lock with BER below 10E-14
Hi, there
I am using the ibert for gty trancesiver. The version of Vivado is 2018.3.
I can see in the hardware manger that the link is up with 0 bit errors. But when I run the scan on the link of the transceivers, I always get the status: incomplete, no matter 1D/2D scan. I have a look at ug908, chapter 14 and 15, did not find any solution there.
Any further suggetions?
David
Re: Serial I/O Scan status reports incomplete, where the link is lock with BER below 10E-14
hello
in order to acquire a statistically valid set of measurements, IBERT needs to wait for a number of samples that is big if your target BER is small. It is possible that you set a target BER so small that this require days for the eyescan to be completed?
i.e. BER = 10^-2 means that you need at least 100 samples to capture one error. But if you are interested to BER = 10^-3 you need to wait at least 1000 samples to capture the first error.
In reality this is more complicated. Please check AR66799
Visitor dawang
Here I am using 10^-5, so should not be too slow.
Also if the progress is slow, should the progress bar with some number increasing to show the progress? In my case, the progress is always 0%.
hello
if you inject an error at transmitter side, is this error captured from the receiver?
Visitor dawang
The injecting error works as expected. Also I can get the eye diagram now.
The changes I made was to change the region and language of my computer, and rebooting my FPGA platform.
But one issue, I set the Serdes to work as 10.3125Gbps, but somehow only get 6.6Gbps from Status column in serial IO. How could this happen?
hi @dawang
you can check if the system clock frequency in IBERT setting can match hardware.
Boris
