bfung
[Shape Builder 18-119] Failed to create DATA-DRIVEN shape for instance XCVR
Targeted Chip: xc7a200tfbg484-2
Full error-message:
[Shape Builder 18-119] Failed to create DATA-DRIVEN shape for instance XCVR/xcvr_i/inst/xcvr_init_i/xcvr_i/gt2_xcvr_i/gtpe2_i. Failed to add instance xcvr_rx_n_pin_IBUF[2]_inst to a new IPAD-GTX shape. The instance already belongs to a shape and its new location conflicts with the one in the existing shape.
Of note, this 7-series chip only has GTP transceivers, though the error mentions GTX.
How to best approach this problem?
bfung
running report_route_status on the implemented design yields the following:
Nets with Routing Errors:
Unrouted Pin: XCVR/xcvr_i/inst/xcvr_init_i/xcvr_i/gt2_xcvr_i/gtpe2_i/GTPRXP
eschidl
hi @bfung ,
you probably have two transceiver instances constrained to the same location.
Please check your design resources and see what locations you have assigned for them.
