Visitor vyudovich
Skew timing violation on Transciever clocks
I am syntesizing a small design with 10Ghz transciever.
The clock scheme is this:
GTYE4_CHANNEL.RXOUCLK --> BUFG --> IBUF --> MMCME4_ADV.CLKIN
from MMCM there are two clocks: 156.25 and 312.5, posedge aligned fed back to the CHANNEL to:
GTYE4_CHANNEL.RXUSRCLK
and
GTYE4_CHANNEL.RXUSRCLK2
After Implementation phase I get Max SKew violation:
Check TypeCornerLib PinReference PinRequiredActualSlackLocationPin
Max SkewSlowGTYE4_CHANNEL/RXUSRCLK2GTYE4_CHANNEL/RXUSRCLK0.881.57-0.69GTYE4_CHANNEL_X1Y51serdes_wrap/serdes_10g/example_wrapper_inst/serdes_10g_inst/inst/gen_gtwizard_gtye4_top.serdes_10g_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[36].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[3].GTYE4_CHANNEL_PRIM_INST/RXUSRCLK2
Would appriciate inputs and ideas why that is happenign and how to resolve.
Vladimir.
Re: Skew timing violation on Transciever clocks
The MMCM does not have tight enough timing constraints to drive the USRCLK inputs of the transceivers.  The preferred way to create the clocks is to drive 2 BUFG_GT's which have the ability to do the /2 function.  This will keep the timing skew within the limits on this device.  See page 110 of UG578.
hi @vyudovich
MMCM is not recommanded.
Please follow this article.
https://www.xilinx.com/support/answers/64047.html
Boris
