rajuponnaganti
Voyager
Voyager
Testing GTX transceivers Using IBERT
We have VC707 baord and 4-port SFP/SFP+ module. We want to test eight GTX transceivers (MGT_BANK_117 & MGT_BANK_119).To test GTX transceivers, we are using IBERT core.We are giving external reference clock 125 MHz, Sys clk is 200 MHz( Pins:E19,E18).I attached Zip file below which contained results and modules what we are using and setup too.
For Near End , it(FMC1) is working fine, Coming to far end, both are not working.What could be the reason?
REF CLK 125MHz, Line Rate 3.125Gbps.
athandr
Put the source (where you are observing the link) in "none" mode and the destination FPGA in far end PCS/PMA mode. Check the status in the Source FPGA.
Anirudh
rajuponnaganti
Voyager
Voyager
As you said, i set none mode, no link took place.what could be the reason? how to resolve it?
athandr
Did you put the destination FPGA in the far end PCS/PMA mode?
Anirudh
rajuponnaganti
Voyager
Voyager
I just want to do loopback test.I connected ofc cable between two sfps.
mcgett
Q1 - How many FMC cards are you using?
      Q1.1 - If the answer is not two then which interface is the FMC card connect to on the VC707?
Q2 -  How many SFP modules are you using?
     Q2.1 - If the answer is not eight (two FMC cards) or four (one FMC card) then which SFP cages are the SFP modules plugged into?
Q3 - How have you connected the optical cables between the SFP modules?  This should be express in the following form:
      Link 0 - FMC#.SFP# to FMC#.SFP#
      Link 1 - FMC#.SFP# to FMC#.SFP#
      Link 2 - FMC#.SFP# to FMC#.SFP#
      Link 3 - FMC#.SFP# to FMC#.SFP#
Q4 - Please provide a picture of your setup.
rajuponnaganti
Voyager
Voyager
A: I am using Two FMC cards
A: 8
A:
We have two OFC cables.While testing, we connected as per requirement.
A:attached zip file which have setup images.
athandr
Sure, i understand this is a loopback test.
Irrespective of whether it is between two different FPGA's or looped back in the same FPGA, you would have a TX and and RX.
So here is how you should setup
1) Connect TX to RX through an external cable (SFP) in your case
2) Now setup ibert in TX and put it in none mode (Observe the link in TX)
3) Now setup the ibert in RX (or you need not setup also) and put it in far end pcs/pma mode.
4) Now check the link in TX GT ibert link only
For more information on the far end near end clarity, please check the UG476 which has a clear diagram on this.
Anirudh
mcgett
>A: We have two OFC cables.While testing, we connected as per requirement.
It is frustrating when you do not provide full and complete information as requested.  This has been a common occurence in this thread and your others.  Based on the pictures, in this case the answer should have been:
Link 0 - FMC1.SFP0 to FMC1.SFP1
Link 1 - FMC2.SFP0 to FMC2.SFP3  <- This does not match the IBERT configuration, FMC2.SFP3 should be FMC2.SFP1
Link 2 - Not connected
Link 3 - Not connected
Your system images shows that you have a TX FAULT indicator on every SFP and this was part of your other thread.  You never responded to any of my questions in post #29 in that thread nor my re-request in post #34.  In post #29 I had said the following:
> Please provide a photo of your test setup that shows the VC707, the FMC card, the SFP and optical cabling.
>> Why TX_Fault is High?(SFP)
>The most likely condition is that the SFP module is not present.  The second most likely condition is that the SFP >module has detected a fault in the TX laser circuits.This may be due to TX_DISABLE being asserted,
In the pictures you provided now, it is clear that you have not installed jumpers on the JP12 TX0:3_DIS pins.  The INF-8074 document that you have posted says in Table 1 "TX Disable, Transmitter Disable, Note 2 Module disables on high or open".  The schematics that you have posted shows that the "TX Disable" pin for each SFP module is open unless the jumper is installed to connect the pin to ground.  This results in the SFP transmitter being disabled.
Installing these jumpers should move you on to the next step.  When you encounter the next issue please read and respond fully to every question that is asked.
rajuponnaganti
Voyager
Voyager
Now I am using FMC1 only.Results are in attched zip file.What is None mode? Is it loopback mode?
I selected different modes as in images. I got unexpected results.Can u explain? for IBERT, it is giving some result.Coming aurora, it is not working.what could be the reason? in simulation it is working.coming to hardware, not working.
I added jumpers as you said.
i added SFP module.
venkata
when you set loopback as "None", it means there is no loopback set in GT. Please refer to loopback section in GT user guide for different loopback modes.
I find the BER is very bad with the IBERT result. With erroneous link, IP cannot link up.
rajuponnaganti
Voyager
Voyager
"IP cannot link up".Here IP means Aurora?
How can we achieve good BER?
What could be the problem?
How can we resilve it?
rajuponnaganti
Voyager
Voyager
I tried one test-loopback between onboard SFP (X1Y2)to SFP on FMC1 daughter card (X1Y24).You can find test setup and chipscope results on zip file. Lane up signal for X1Y2 is toggling and pll_lock signal for X1Y24 is toggloing. Ref clock is 125 MHz, INIT_CLK is SYS_CLK,Board :vc707,aurora 64b66b,streaming.What could be the reason?How can we resolve it?
mik3l3_hdl
Hi guys,
I am try to run a similar test with an FMC with 4 SFP+  , card name FM-S14.
In this test I am implementing a loopback test on the first SFP on which i plugged a loopback bridge (MOLEX).
The design works fine only in Behavioral simulation but  not in Post-Synthesis neither on the real FPGA.
I am providing  to the FM-S14 the signals necessary to activate the laser as follow:
rate_sel1 <= '1'; -- Channel 0 have SFP module run at full bandwidth
tx_disable1 <= '0'; -- Channel 0 enable SFP modules
BUT anyway the channel, the lane and the aurora core itself (signal s_axis_tx_ready)  are always down to zero.
They are only up with during behavioral .
When I flash the bitstream on  the FM-S14 card, only the led od channel 1 is blinking red the others are turned of.
Weird also because I am trying to drive channel 0 and not channel 1.
I have tested all the 4 channels but the situation is the same.
I have tried various FS card  but i got always the same situation.
Anyone of you has any suggestions please?
Thanks a lot
rajuponnaganti
Voyager
Voyager
Hi ,
i Sha project which is used to generate bitstream.
Which protocol is used ?
mik3l3_hdl
Protocol used is Aurora64b66b
on Ultrascale+ vcu118 xcvup9 ,  with Vivado 2018.2 HLS.
Mike
