greenghecco
Testing the SFP module ML605
Hello i am using a proprietary protocol for fiber.
I wanted to test the SFP module with a simple design, which loops the incoming logic levels back to the output.
Therefore i wrote a very simple module:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
Library UNISIM;
use UNISIM.vcomponents.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity top_test is
    Port ( Input : in  STD_LOGIC;
			  Input_n : in  STD_LOGIC;
           Output : out  STD_LOGIC;
			  Output_n : out  STD_LOGIC;
			  Disable_TX : in STD_Logic;
			  SFP_LOS : out STD_logic
			        -- 125MHz clock output from transceiver
end top_test;
architecture Behavioral of top_test is
signal shortcut : std_logic;
begin
IBUFDS_inst : IBUFDS
   generic map (
      DIFF_TERM => FALSE, -- Differential Termination
      IBUF_LOW_PWR => FALSE, -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
      IOSTANDARD => "DEFAULT")
   port map (
      O => shortcut,  -- Buffer output
      I => Input,  -- Diff_p buffer input (connect directly to top-level port)
      IB => Input_n -- Diff_n buffer input (connect directly to top-level port)
   OBUFDS_inst : OBUFDS
   generic map (
   port map (
      O => Output,     -- Diff_p output (connect directly to top-level port)
      OB => Output_n,   -- Diff_n output (connect directly to top-level port)
      I => shortcut -- Buffer input
end Behavioral;
 And set the ports in the UCF:
##SFP Module
INST "Input" LOC = "E3";
INST "Input_n" LOC = "E4";
INST "Output" LOC = "C3";
INST "Output_n" LOC = "C4";
 But i get the following error during mapping:
ERROR:Pack:1107 - Pack was unable to combine the symbols listed below into a
   single IOB component because the site type selected is not compatible.
   Further explanation:
   The component type is determined by the types of logic and the properties and
   configuration of the logic it contains. In this case an IO component of type
   IOB was chosen because the IO contains symbols and/or properties consistent
   with input, output, or bi-directional usage and contains no other symbols or
   properties that require a more specific IO component type. Please double
   check that the types of logic elements and all of their relevant properties
   and configuration options are compatible with the physical site type of the
   constraint.
   Summary:
   Symbols involved:
   	PAD symbol "Input" (Pad Signal = Input)
   	DIFFAMP symbol "IBUFDS_inst/IBUFDS" (Output Signal = shortcut)
   Component type involved: IOB
   Site Location involved: E3
   Site Type involved: IPAD
   single IOBS component because the site type selected is not compatible.
   IOBS was chosen because the IO contains symbols and/or properties consistent
   with differential slave usage. Please double check that the types of logic
   elements and all of their relevant properties and configuration options are
   compatible with the physical site type of the constraint.
   Summary:
   Symbols involved:
   	PAD symbol "Output_n" (Pad Signal = Output_n)
   	SlaveBuffer symbol "OBUFDS_inst/SLAVEBUF.DIFFOUT" (Output Signal = Output_n)
   Component type involved: IOBS
   Site Location involved: C4
   Site Type involved: OPAD
   single IOBM component because the site type selected is not compatible.
   IOBM was chosen because the IO contains symbols and/or properties consistent
   with differential master usage. Please double check that the types of logic
   Summary:
   Symbols involved:
   	PAD symbol "Output" (Pad Signal = Output)
   	BUFINV symbol "OBUFDS_inst/OBUFDS" (Output Signal = Output)
   Component type involved: IOBM
   Site Location involved: C3
   constraint.
   Summary:
   Symbols involved:
   	PAD symbol "Input_n" (Pad Signal = Input_n)
   	SlaveBuffer symbol "IBUFDS_inst/SLAVEBUF.DIFFIN" (Output Signal =
   IBUFDS_inst/SLAVEBUF.DIFFIN)
   Site Location involved: E4
 Do i have to change any description in the ucf?
barriet
The transceiver (GTX MGT in this case) pins are special. You can't treat them like normal SelectIO, e.g. infer IBUF -> fabric loopback -> OBUF.
These pins directly connect to the GTX, are dedicated function, and IO standards, etc.
While you could make a fabric based loopback by instantiating the GTX (see the user guide or Arch Wiz for example interfacing code), probably a far easier solution is to use the IBERT core and then configure it via the IBERT Analyzer to be in far-end loopback. That solution will handle the GTX, JTAG connectivity via the BSCAN (ICON), DRP interface for transceiver configuration, etc. That's a much easier way to get there for a quick loopback design.
http://www.xilinx.com/support/documentation/dt_chipscopepro_chipscope14-2.htm
 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/chipscope_pro_sw_cores_ug029.pdf
 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/ug811_ChipScopeUsingIBERTwithAnalyzer.pdf (ChipScope Pro Tutorial: Using an IBERT Core with ChipScope Pro Analyzer)
bt
barriet
bt
greenghecco
Thank you for the tipps. I will try this.
Hello, I also want to use SFP on the ML605 board. In the IEE V14.7 environment, I used Ibert. I need to SFP only use the receiver. So I need PAD X0Y17_RX_P and X0Y17_RX_N, but when I look at the HDL Instantion Template, then there is a lot of PAD, not needed to me. I do not know what to do with PADs. How to correctly configure SFP to the receiver?
p.s. I take the CLK on the board from the SMA connectors, the frequency is the same as on the transmitter
Tags (3)
