fft123
The bitstream files generated by Rapidio evaluation IP do not work properly for long periods of time
Hello
I would like to ask that the bitstream files generated by Rapidio evaluation IP do not always work well when loaded into the device. After about two hours, they no longer work well.
karnanl
Hello @fft123
If you are using evaluation license, then it is normal to see IP stops working after some times.
( Time limit is depends on the IP and clock frequency used for ticking the timer )
See also :
https://forums.xilinx.com/t5/Video/mipi-csi-2-RX-operation-time-limit/td-p/923116
Leo
Versal Blogs
karnanl
Hello @fft123
Do you have any updates on this post ?
If you find my answer was useful, could you please kindly marked this thread as Solved, so other users can learn from your experience ?
Thanks & regards
Leo
Versal Blogs
