Participant tobis
Transceiver wizard 1.7, free run clock
Hey guys,
based on an older 7 series design i try to implement a transceiver with dynamic line rate change for an Ultrascale+.
I understood that i have to use the calibration block if CPLL is used and line rate changing is desired.
In the old 7 series wizard, the free-run/DRP clock we used was 125MHz for supporting line rates from 1.25G up to 6.25G.
In the newer Transceiver wizard 1.7 for the Ultrascale+, the free-run/DRP clock is automatically limited depending on which line rate i put in. For instance the wizard limits the free-run clk to 78.125MHz if 3.125G is selected.
Now i am confused which free-run/DRP clk frequency I have to choose if my transceiver should support line rate from 1,25G to 6,25G??? Or do i have to dynamically change this frequency depending on line rate?
Cheers!
Re: Transceiver wizard 1.7, free run clock
Hi @tobis,
please check with pg182, page 10/11, where this limitation is coming from. The dependency comes from the USRCLK2 used.
Just check with all line rate setups you want to use, what would result in the lowest frequency limit for the free running clock, and take this lowest frequency (or a lower one) as your free running clock for all setups. Then you would not need to change when stepping through your line rates.
Hi @tobis,
Advisor evgenis1
Advisor
Hi @tobis ,
I've recently posted a related question [link]. The max speed of free-running DRP clock depends on the data width. I think you can choose the lower of two speeds.
Evgeni
Tags (2)
