UG576 Figure 2-29 is wrong
I was implementing DRP interface for Ultrascale+ GTH and found an error in UG576 Figure 2-29:
DRPWE should not go high for Read operation.
Table 2-38:
DRP write enable.
0: Read operation when DRPEN is 1.
1: Write operation when DRPEN is 1.
This should be corrected in next version of UG576.
Re: UG576 Figure 2-29 is wrong
Hi @pejdstran ,
thanks for pointing this out.
There exists already a request to update this, so it should be updated in the future.
Hi @pejdstran ,
