12-23-2020 02:59 AM - edited 12-23-2020 07:11 AM
I am using ZCU216 EVB(xczu49dr-ffvf1760-2-e-es1 part) and VIVADO 2019.2.1.
I want to make an example design of FRACXO IP with GTY transceiver. ( I using xapp1276 )
I downloaded the design files form the xapp1276 and ran it in Vivado but I was not able to make example design of FRACXO IP with GTY trans. (I have only GTY example design files)
I followed the instructions below:
It is strongly recommended to be familiar with the example design. Recommendation on constraints, clocking, resets, GT connections and settings must be respected.
Please refer to XAPP589, XAPP1241, XAPP1276 and XAPP1308 for operating instructions
1) Install Xilinx Vivado 2016.4 or later tools.
2) Add the IP repository to your project: Tools-->Project Options, select IP on the left pan, click "Add Repository" and select PICXO_FRACXO folder
In non project mode, the following commands can be used:
>>set_property ip_repo_paths <path to ip repository>/PICXO_FRACXO [current_fileset]
>>update_ip_catalog
3) In the IP catalog, select PICXO_FRACXO, right click-->Customize IP
In non project mode, the following command can be used:
>>create_ip -name PICXO_FRACXO -vendor xilinx.com -library ip -module_name ip_name
4) Right Click-->Generate Example design
Is there something I'm missing , how can I made a working example design of FRACXO IP with GTY transceiver?
Thanks!
Patolsky
01-13-2021 10:16 AM
HI @patolsky
First note that XAPPs are usually tested (thus supported) in a single tool version. In the case of the xapp1276 this is 2019.1.
So if the project is not working or not building properly, I would highly recommend to go back to the version mentioned in the xapp.
With that said I think I have found the issue as I was able to make it build in 2020.2. The 2 following steps need to be done:
