01-23-2020 03:37 AM
Hi Team,
I am using ultrascale plus SoCs, I simulating PCIe gen3 using IBIS-AMI files and corresponding S-parameter files of die termination and package.
Simulated same traces with GTH and GTY IBIS-AMI models and I found that, the simulation which used GTY models passing and GTH failing.
Both cases stackup and trace were same, only difference was IBIS-AMI and S-parameter models of Package and die termination.
03-09-2020 11:53 PM
Hello @mufeed029
Do you have any updates on this post ? Did you find any solution ?
If you find @jhua 's answer is useful, could you please kindly marked this thread as Solved , so other users can learn from your experience ?
Thanks & regards
Leo
02-20-2020 04:20 PM
Hi @mufeed029
Can you share the testbenches of your GTH and GTY runs?
Are you setting the AMI paramters per each of their own User Guides as included in the model package?
We would expect the GTH and GTY to both work at your 8 Gbps line rate. Let's take a look at your setups to see if there is anything not configured correctly.
03-09-2020 11:53 PM
Hello @mufeed029
Thanks & regards
Leo
