Unroutable gtrefclk connection from BUFG_GT
Hello guy.
I am using the 10G Ethernet IP Core and the 1G Ethernet Sgmii IP from Xilinx for a Zynq Ultrascale device.
Both are using Tranceivers. For the 10G, we have an external differential clock input. For the 1G not.
My idea was, to connect the gt_refclk_out signal from the 10G IP to the gtreclk from the SGMII IP .
The SGMII IP is used with shared logic in example design. See picutre below:
After the Implementation, i see an unroutable behaivior.
In the schematic, i see that a BUFG_GT is used for the gt_refclk_out.
So what is wrong in this routing? Can't i connect a BUFG_GT to gtrefclk of a Tranceiver?
How can i solve this problem?
Thank you very much
回复: Unroutable gtrefclk connection from BUFG_GT
hi @astei87
gt_refclk_out seems connected to ODIV2 of IBUFDS_GTE4. ODIV2 cannot drive GTREFCLK.
we may have to figure out how to bring the IBUFDS_GTE4 out of the IP.
You can select Chared Logic in Example design and manually instantiate the IBUFDS_GTE4 and GT COMMON in the block design.
Boris
hi @astei87
Boris
thx borisq,
ok i instantiate the 10G IP with shared logic in example design. The i instantiate the IBUFDS_GTE4 and connect the output to
both (10G and 1G) IP's, right?
I have another question. We have already a differential input Clock also for the 1G Sgmii IP but it is to high. It is 625 Mhz.
The maximum clock i can select in the IP is the 312,5Mhz. Could i devide this clock and drive the GTREFCLK?
But the IBUFDS_GTE4/ODIV2 doesn't work you said. Is there another possibility?
Thanks very much.
hi @astei87
I think you can select "GT in Example Design".
you can use GT Wizard to generate GT, where 625Mhz is allowed for 1.25Gbps.
Boris
ok, but how can i use the SGMII IP then? Because there is already a GT included.
Can i somehow replace my GT Core with that one in the IP?
hi @astei87
if you select GT in Example Design, the SGMII IP doesn't include a GT.
Boris
ahh i see, i haven't noticed this Checkbox.
Thank you very much
one last question.
You have said, that i could instantiate my own GT and select 625Mhz.
Why is this configuration then not possible in the SGMII IP Core? There i can select till max 312.5Mhz.
It must be a special reason for that, isn't it?
Thank you
hi @astei87
I guess the SGMII IP only tested with those ref clocks in the list.
Boris
