Participant nishantseth07
Use GTX SMA Transmitter of ZC706
I want to transmit my data using GTX SMA transmitter of ZC706 board. I have gone through the zc706 user guide but didn't get any solution. Is there is any example code is available to understand the procedure of data transmission using GTX SMA.
Thanks in Advance.
Teacher xilinxacct
Re: Use GTX SMA Transmitter of ZC706
@nishantseth07
This may be helpful... https://www.xilinx.com/support/documentation/boards_and_kits/zc706/2014_4/xtp243-zc706-ibert-c-2014-4.pdf
If you want to search for more... using 'transceiver' may give you better results than transmitter.
Hope that helps
If so, please mark as solution accepted (Kudos also are welcome :-)
Hi Xilinxacct
Thanks for your reply.
I have gone through the PDF link provided by you and made a xilinx project as per instructions are given. But if I want to send my data using GTX SAM in the same code then where should I change or add my data.
What I want to do is that I want to transmit my signal through GTX SMA and captured it in the spectrum analyzer.
You can send PRBS data by using IBERT.
If you would like to send custom pattern, you can build a GT example design, then modify the txdata in the example top level. See PG168 for GT wizard usage. Follow Chapter 4 on page 36 to generate GT example design.
HI Jhua
What is the maximum clock rate is available to be used in GTX transceiver?
Is it possible to transmit data at 10GbpS using internal clock?
hi @nishantseth07
I idea for GTX to transmitter high speed data is like this.
you provided a reference clock first. The PLL can boost the frequency to very high speed upto 10.3125Gbps line rate (or ~5Ghz serial data clock) for the Zynq device on ZC706. The serial data is clocked by the high frequency clock on both edges.
- which clocks? User clock or GT internal serial clock?
For serial PMA clock, the max frequency is about 5Ghz. Half of the max line rate.
The max allowed user clock frequency can be found at DS191 Table 96
http://www.xilinx.com/support/documentation/data_sheets/ds191-XC7Z030-XC7Z045-data-sheet.pdf
- 10Gbps is possible. you may have to provide a reference clock to the dedicated clock inputs. For example, SMA_MGT_REFCLK_P/N.
Boris
I created a new project for GTX the setting gor ibert ip is attached. After that i created example IP design and created bit file and boot the FPGA with generated boot file. In the hardware J33 is connected to J34 and J32 is with J35. BUt after program the FPGA i am getting IO links.
So i will check that my GTX transceiver is working with internal clock?
hi @nishantseth07
I see you select  MGTREFCLK0 of Quad 111 as reference clock.
This clock comes from a FMC daughter card on ZC706. Please see below.
Did you attach the FMC daughter card?
If you don't have FMC card, you can select MGTREFCLK1 of Quad 111 and you can provide clocks through SMA Cable if you have a clock generator.
Boris
HI
I did the changes but still NO-LINK in tx and RX PLL is shown. As i understood the MGTREFCLK1 of Quad 111 is also an external clock. I do not have external clock generator and i want to use the internal clock . So how to use internal clock?
hi @nishantseth07
yes, you are right. Quad 111 MGTREFCLK1 needs external clock generator.
If you don't have any external clock source, you can use the Quad 110 MGTREFCLK1.
It is a programmable clock generator (SI5324) on the ZC706 board.
You may need to program the clock generator through I2C interface for desired frequency.
You can implement it with RTL or use MicroBlaze with I2C...
Boris
