kangsungsik
Using transceiver in KCU116.
Now i'm using KCU116 evaluation board.
i try to transfer data by aurora communication from KCU116 to ZC706.
According to ug1239, KCU116 board provides 16 GTY transceiver
• Eight of the GTY transceivers are wired to PCI Express® x8 edge connector (P1)
• Four of the GTY transceivers are wired to FMC HPC0 connector (J5)
• Four of the GTY transceivers are wired to zSFP/zSFP+ module connectors (J1, J3, J4, J6)
I want to use SMA connector for accessing GTY rather than PCIe,FMC,SFP.
Is it impossible?
thankyou
zhiq
Hi @kangsungsik
The simplest way is to use the SFP, you only need connect the sfp module between two boards. But I'm not sure if  you have this kind of module?
FMC is a liitle complex, as you need a externed card.
zhiq
Hi @kangsungsik ,
 I have quick checked the sch of KCU116, there're four sma on the board, but they are not connected to GT channels of the device. So you cannot directly use the sma on the board.
If you want, you can use a FMC card to fanout out the GT channel to the SMA. But it's a little complicated.
kangsungsik
thanks for your reply. @zhiq
Can i ask you one more question?
i find that there are PCIe ,SFP ,FMC connector which is connect with GT in both KCU116 and ZC706 board.
Which one is easier to use? Like i said in the post, my application is  data transferring between 2 Board by using aurora.
I've never used all three connector.
zhiq
Hi @kangsungsik
kangsungsik
thank you @zhiq .
I will try with SFF connector module.
Have a nice day!
