Visitor purtsjon
Virtex 6 GTXE1 DRP Register for TX Phase/Delay
For the 7 series FPGAs there are DRP registers available for TX phase/delay alignment configuration on GTXE2. Kintex7:
TXPH_CFG (0x64)
TXDLY_LCFG (0x9F)
Are there any similiar (undocumented?) registers on a Virtex 6 to control the TX phase/delay alignment during runtime like on Kintex7?
In UG366 I can't find any way...
Thanks for your support.
Jonas
Tags (2)
回复: Virtex 6 GTXE1 DRP Register for TX Phase/Delay
hi @purtsjon
Virtex-6 GTX is a little different than 7 series GTX with phase and delay alignment feature.
Some features in 7 series GTX may not be applicable with Virtex-6 GTX.
why do you need to change those attributes during runtime on Kintex-7? what do you need in the application?
Boris
Visitor purtsjon
Hi @borisq
The top priority is to get a deterministic timing of the TX path in the transceiver.
On the Kintex7 the automatic alignment has been disabled and the phase interpolator between PCS und PMA controlled manually depending on the TX FIFO half-full flag. This was a recommendation by a Xilinx expert.
When the automatic alignment was used some slight phase changes were seen after a link is re-established...
Now, we like to get the system working on a Virtex6 too. But this would require that the phase/delay alignment behaves similar...
Could you give some details about the differences?
jonas
