Vivado Simulator 2019 runs forever for GTY transceiver example project
Hi All,
I have created a project using Vivado IDE for GTY transceivers. Further for simulating it, I ran the steps given in the documentation for example project. This exmaple project was also successfully created and when I run simulation, it runs for ever without the link success flag as part of simulation?
Have you folks run into any issue similar to this? Further any clue as what is to be done for this to resolve this issue?
Hariharan K Srinivasan.This is the snapshot from Xilinx DocumentationThis is the snapshot from Xilinx DocumentationThis is my run from Vivado simulatorThis is my run from Vivado simulator
Re: Vivado Simulator 2019 runs forever for GTY transceiver example project
this signal is latched, you should clear it after everything is going fine.
回复: Vivado Simulator 2019 runs forever for GTY transceiver example project
hi @harisrini
does TXRESETDONE and RXRESETDONE go high?
thanks,
Boris
The problem may exist for two reasons.
1. The GT reset sequence is not completed successfully. (it could be monitored through TXRESETDONE and RXRESETDONE and RXPMARESETDONE and TXPMARESETDONE)
2. The loopback is not vorrectly established. (this could be checked as if the PRBS generator/checker works correct and loopback connectivity is well established)
In addition, there are other things that can slow down the whole process.  I would run for a full 3 milliseconds to make sure it was stuck.
Thanks all for the reply. I got the simulation up and running. Actually the problem was with my set-up and I was overwirting the same project at multiple place and tool perhaps did not understand it properly. Now it is sorted and link is trained and link is up properly.
