Vivado Transciever Wizard not showing 16-bit datapath for VU9P
Looking at AR#69011, the latency of a 16-bit datapath is about half that of a 32-bit datapath for GTY transcievers. However, when I open the transciever wizard (both for Vivado 2018.3 and 2019.1), there is no option for a 16-bit datapath. Is this not supported?
its a question of how fast the fpga can get data into / out of the GTY.
If you have a line rate of say 10 Gb/s , then the clock rate for a 16 bit interface is to much for the FPGA,
      so the minimum is a 32 bit user interface.
If you were to drop the GTY line rate down to say 3 Gb/s , then you have the option of a 16 bit interface.
Please give Kudos if this was useful and close if it aswers your question.
Makes sense. Just curious-- is there a document that shows the maximum line rate for the different widths?
Sorry , dont know of said doc, Im certain its 'just' an equation,
but I'm lazy,
   I just tend to run the tool, it does all the nice calculatoins !!
Hi @cgonzo ,
have a look at the datasheet for the maximum user clock frequency for the transceiver. It is listed for the different data width. Then multiply the two.
