What does "The peak-to-peak differential voltage is defined when TXPOSTCURSOR = 5'b00000 and TXPRECURSOR = 5'b00000" mean?
About the note "The peak-to-peak differential voltage is defined when TXPOSTCURSOR = 5'b00000 and TXPRECURSOR = 5'b00000"  in Table 3-35 of UG578,
What does it mean?
It means that the Vpp value in Table 3-35 is measured when set  TXPOSTCURSOR = 5'b00000 and TXPRECURSOR = 5'b00000?
If my guess is true, then how do I know the real Vpp value when I config GTY by using below setting?
(TXPOSTCURSOR = 5'b01111 and TXPRECURSOR = 5'b00000 and TXDIFF = 5'b01000)
Best,
回复: What does "The peak-to-peak differential voltage is defined when TXPOSTCURSOR = 5'b00000 and TXPRECURSOR = 5'b00000" mean?
hi zan_zhan@amat.com
your understanding is correct.
you can use the following tool for calculation.
https://www.xilinx.com/support/answers/70619.html
or you can run ibis ami simulation.
Boris
Boris
