Why use the Trasceiver Wizard?
Hello, seems like I'll always be a newbie but I have a question about the Transceiver Wizard. I see in the Transceiver Wizard that I can pick the Transceiver Configuration such as Aurora64B/66B which is okay and I can also drop in an Aurora64B/66B IP block on my Block Design. So what is so special about the Transceiver Wizard?
Thank you,
Joe
Re: Why use the Trasceiver Wizard?
Hello Joe
If Aurora 64B66B IP can fit your system requirement, please use Aurora 64B66B IP then. There is no reason to use Transceiver wizard.
( Aurora 64B66B IP has a transceiver macro inside, which is generated by transceiver wizard )
But for users who wants to use "non-standard" protocol, they need to use transceiver wizard to use FPGA transceiver macro features.
There are also some protocols that Xilinx does not have the IPs to support (i.e: SATA, SLVS-EC, MIPI C-PHY, V-by-One) , in this case IP vendors built their IPs with Xilinx transceiver macro inside (which generated by transceiver wizard )
Without transceiver wizard, users need to set transceiver attributes/register one-by-one for thier use-case, which is not an easy task.
Thanks & regards
Leo
Hello, thank you for responding to my message. Quick question for you. I like using the Block Design for my modules but when I click on the + and try to find the Transceiver Wizard it is not listed. Why can't I instantiate the IP in the Block Design?
Respectfully,
Joe
The transceiver wizard just doesn't support block design so far.  It will offer that support in Versal designs at least to a certain degree.  I believe you can do an IP example design and manually make a wrapper for the wizard IP that can be placed into your block design.  I know this is not ideal.
