XAPP1295 Error
Target: VCU118
I am following the instructions given in XAPP1295 to insert the debug logic into my .dcp.
When I enter the command: insert_gt_dbg analyze <.dcp file> the following is the output in the TCL console:
INFO: [Project 1-604] Checkpoint was created with Vivado v2017.2.1 (64-bit) build 1957588
open_checkpoint: Time (s): cpu = 00:00:42 ; elapsed = 00:00:40 . Memory (MB): peak = 9617.531 ; gain = 0.000 ; free physical = 110307 ; free virtual = 120984
Step 1 - checking design for GT and BUFG instances and prepare insert_gt_dbg.do
checking clock network ... INFO: [Timing 38-35] Done setting XDC timing constraints.
report_clock_networks: Time (s): cpu = 00:00:58 ; elapsed = 00:00:15 . Memory (MB): peak = 9931.262 ; gain = 313.730 ; free physical = 109758 ; free virtual = 120435
WARNING: [Vivado 12-180] No cells matched 'get_cells -hier -filter {IS_PRIMITIVE==1 && LIB_CELL=~"*BUFG*" && LIB_CELL!~"*SYNC*"}'.
can't read "::_igd_clk_d": no such variable
Re: XAPP1295 Error
please can you open the synthesized design and then manually generate the .dcp? I am concerned that in the dcp you are using something is missing.
-GG
Re: XAPP1295 Error
hello,
how have you created the .dcp file? have you opened the synthesized design and then saved the .dcp?
is it a complete example design?
thanks
Giovanni
Re: XAPP1295 Error
@gguasti The .dcp was created automatically when I synthesized my design. I copied this file for use in the instructions given in XAPP1295. This design is a complete user design which includes a GTY quad which I'd like to debug with the interface.
Re: XAPP1295 Error
-GG
