XAPP1322 Error
Target: VCU118
I am working on XAPP1322 which uses the debugger tool in XAPP1295.
Following the instructions in XAPP1322, I have finished configuring the debug ports and am ready to generate the bitstream. When I click the "generate bitstream" button, I receive the following errors:
/usr/local/bin/vivado: line 25: /usr/local/bin/setupEnv.sh: No such file or directory
/usr/local/bin/vivado: line 43: /loader: No such file or directory
while executing
"exec vivado -mode batch -source $project(path)/run_viv_syn.tcl -log $project(path)/modify.log"
(procedure "ex_synthesis" line 5)
invoked from within
"ex_synthesis"
("after" script)
Re: XAPP1322 Error
It seems hardware server not setup correctly on your machine. You can follow the instructions mentioned in this post
https://forums.xilinx.com/t5/Installation-and-Licensing/how-to-install-Vivado-Hardware-Server-for-Linux/td-p/659641
Thanks and Regards
Balkrishan
