labluxor8
Zynq Ultrascale+ SMA MGT Clock input
Hi everybody,
I have two questions about the two SMA MGT Clock inputs (p and n).
- I saw in the User Guide that these two input ports do not have a standard I/O and that they are series-capacitor coupled. As I understand, I can provide a LVDS (18 or 25) clock to these ports, right? I tried to generate a 156.25 MHz clock from a ZedBoard and output the differential clock through the FMC SMA outputs with a Xilinx FMC 105 Debug Mezzanine. I checked the output on an oscilloscope and I saw the two waves with approx. (single wave values) 800 mV offset and 800 mV amplitude (over the offset voltage). Unfourtunatelly, nothing happens when I connect the clock to the Ultrascale and the Transceiver is not working. Are there some specs I'm missing? It is ok with that clock source?
- Just to be sure. I need to have a transceiver perfectly edge-synchronized with other hardware logic on the Ultrascale. As I understand, the SI570 oscillators cannot be share between Transceiver Bank and other bank, right? For example, I cannot use the USER_MGT_SI570_CLOCK1_C_P as a clock for my fabric logic. Viceversa, I cannot use the USER_SI570_P as a clock for the transceiver.
Thank you very much,
Andrea
Note: I noticed that in the UG1182 (table 3-13 page 44) there is an error since the USER_SI570_P(N) are set to be at N27 and N28 pin while they are at J28 and J27 as indicated all around the UG1182 and in the ZCU102 Master XDC file
labluxor8
Ok, apperently I found out the solution.
I simply missed some specs in the BUFG_GT.
Writing all specs just do the job:
BUFG_GT GInst(
     .I(FabricClkBuf),
     .CE (1'b1),
     .CEMASK(1'b1),
     .CLR (1'b0),
     .CLRMASK(1'b1),
     .DIV (3'b000),
     .O(FabricClk)
roym
You cannot drive the mgt with any clock that doesn't come into a designated reference clock input but you can use a reference clock input to both drive the mgt and your standard logic.  The IBUFDS_GTE* buffer has 2 outputs as show on page 25 and one of them can drive a BUFG_GT into the Fabric.  For that board you should be good to use the USER_MGT_SI570_CLOCK1_C_P for both the MGT and the fabric.
example:
IBUFDS_GTE*  refclkInst(
    .I (userMgtP),
    .IB(userMgtN),
    .O(gtClk),              // drives GTHE*_CHANNEL without further gating (do not run this one through a bufg)
    .ODIV2(FabricClkBuf));
BUFG_GT GInst(
             .I(FabricClkBuf),
             .O(FabricClk));   //drives any fabric logic gate
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
labluxor8
Hi roym,
thank you very much for your answer.
I did what you suggested but after many tries it seems to me that the clock is not coming out from the ODIV2.
It is possible that there is a problem with the IBUFDS_GTE4 parameters?
I left the default value for the parameters which are the same indicated at page 26 of ug576
https://www.xilinx.com/support/documentation/user_guides/ug576-ultrascale-gth-transceivers.pdf
I'm talking about REFCLK_EN_TX_PATH, REFCLK_HROW_CK_SEL and REFCLK_ICNTL_RX.
What it could be?
Thank you,
Andrea
labluxor8
BUFG_GT GInst(
     .I(FabricClkBuf),
     .CE (1'b1),
     .CEMASK(1'b1),
     .CLR (1'b0),
     .CLRMASK(1'b1),
     .DIV (3'b000),
     .O(FabricClk)
