Observer joebrt
aurora channel bonding using back channel on 64B/66B
I understand that channel bonding is a "start of day" initialization only and once bonded then no further channel bonding exchanges between RX and TX are required (where RX and TX are simplex designs of Aurora interface using different reference clocks).
Is my understanding correct?
Is the skew between lanes considered static once compensated for - regardless of PPM / drift between TX and RX clcoks?
Re: aurora channel bonding using back channel on 64B/66B
Hello @joebrt
Thanks for the update.
Could you please kindly marked this thread as solved , so anyone else can learn from your experience ?
Thanks & regards
Leo
Hello @joebrt
Aurora 64B66B is using the same block code for Idle / Not Ready / Clock compensation / and Channel-Bonding.
Please see SP011 page 40-41.
http://www.xilinx.com/support/documentation/ip_documentation/aurora_64b66b_protocol_spec_sp011.pdf
The skew between lanes should be static, regardless the PPM difference.
But, even if TX is intentionally shifted the skew, RX should be able to adapt (re-do channel bonding ) , since TX is sending Channel bonding codes periodically.
When there is a skew changes between lanes, RX will assert HARD_ERR, and re-do IP initialization process.
Hope this helps
Leo
Observer joebrt
So TX sending channel bonding sequences is periodic regardless of the link state and not just an initilazation step?
Since block code for Idle / Not Ready / Clock compensation / and Channel-Bonding is exactly the same,
TX will send this code periodically even after channel up is asserted.
Observer joebrt
Thanks. that answers my question.
Hello @joebrt
Thanks & regards
Leo
