01-02-2020 09:56 PM
i need to use the GTX transceivers for sending some signals from one board to another. they are uni-directional.
due to the IO limitations i need to use the GTX to serialize in one board and de-serialize in the other board.
is there any basic example project or document on using these high speed serial transcievers ?
i need to communicate ~200 signals at 10 MHz.
01-05-2020 03:55 AM - edited 01-05-2020 04:05 AM
You can use 7 Series FPGAs Transceivers Wizard in Vivado.
After creating the ipcore you can right click an select "Open IP Example Design"
You can use Aurora protocol.
If you are not familiar with GTX Transceivers I would suggest you to first read pg168 and ug476.
By the way, the minimum line rate in GTX is 0.5 GBPS.
