gtx sata3 device phy configuration
Hi, I have a custom board with kcu160 fpga.
I want to bridge fpga from PC to SSD:
PC <=sata3=> (gt0) kcu160 (gt1) <=sata3=> SSD
I used a gtx IP with state machine based on below code:
https://github.com/CoreyChen922/sata_2_host_controller/blob/master/sata_2_core_and_test_app/ISE/rtl/sata_phy/oob_control.v
link between fpga and SSD configured correctly; but link between PC and fpga doesn't configured.
I dont have any signal (comreset or cominit) on IP. I think the link is dead!
When I turn on my PC, I connect a SSD to sata port for configure sata. I checked the tx pins with oscilloscope and I saw some signals on it. I think its comreset received from PC, but I cant detect it in IP.
Any body can help me how can I detect cominit or comreset in gtx IP base on OOB and device position?
thank you.
Hello @johnblackxilinx
It seems that the code is created for Virtex-5 transceivers.
I can see these code is using RXELECIDLE signal for handshake procedure.
What is KCU160 , I cannot find it in device list. ( Is it Kintex UltraScale ? or 7-series ? )
Anyway RXELECIDLE for both devices (GTX/GTH/GTY) are not useable for line-rate above 2.5Gbps.
Please see also UG476/UG576/Ug578 "RX Out-of-Band Signaling" section.
RXELECIDLE may not behave as expected if the line-rate is above 2.5Gbps.
Leo
Hi  @karnanl . thanks for reply.
I use xc7k160tffg676 (gtx 7 series). sorry! kcu160 was my mistake.
You are write, but I can't detect any signal on any pins of gtx IP from PC for start link. I send cominit with assert tx_cominit pin of IP, but I cant receive anything!
I dont have any problem from FPGA to SSD for creation link. All of pins (comminit,comwake, rxelecidle, etc) work correctly.
Hello
>PC <=sata3=> (gtx0) Kintex-7 (gtx1) <=sata3=> SSD
I see, so the blue side is okay, but the red side has an issue.
Could you please use oscilloscope to compare OOB signal from PC and SSD ?
Is there any difference on the OOB signal (swing-level, burst-rate, gap-width) ?
Is RXELECIDLE asserted on gtx0 ?
Leo
Hi, I used the new sata cable and its worked!
But I have now another problem.
In device mode (PC <=> FPGA), when I transmit comwake and after that send align signal (x"7b4a4abc"), I receive "4a4a4a4a" and after receive some other data and after that cominit signal and start again!
After rxelecidle0 deasserted, rxdata and rxcharisk were undefined!
device:
host:
In sata3 standard whan device transmit align signal, Host should transmit align signal and link start. but I don't know why I don't receive align signal.
Can you help me? thank you.
Hello ,
Did you try to assert RXCDRHOLD  before sending COMINIT,
and deassert RXCDRHOLD after receiving COMWAKE  ?
Please see also explanation mentioned in UG476 below that we do recommend to assert GTRXRESET after deasserting RXCDRHOLD.
Leo
