gcsimmonsjr
iBert on Kintex-7 -1 speedgrade set for 5.94Gbps, but only comes up at 2.97Gbps
We have a multi-Kintex FPGA design that is using Aurora 64/66 protocol channels to communicate between FPGAs. We're running these at 6Gbps.
We used iBerts to test these channels initially, but we would like to test and fine-tune these now. Unfortunately, we can only seem to get the iBert up to 2.97Gbps. We have QPLL's running at 148.50MHz and a system clock of 200MHz. Configuring the iBert IP says that the channels should be running at 5.94Gbps, but they are not. Only 2.97Gbps.
I downloaded Vivato 19.1, and re-built everything from the example design. No Joy.
What are we doing wrong here?
roym
Normally the issue here is specifying the wrong frequency of the system clock that is used measure the output frequency.  I normally use the reference clock (internal clock) as the system clock and avoid this complication.  I haven't seen a case where the measurement wasn't the problem.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
gcsimmonsjr
Are you saying use the MGTREFCLK as the system clock?
gcsimmonsjr
I changed both the sending side and the receiving side system clock source to be Quad115_0. I'm assuming this is MGTREFCLK0.
The receiving side now says 4.000Gbps. Still not 6. Also, it doesn't matter what the sending side is set to, the receiving side always says 4.000Gbps.
This is nuts. This should really work - and easily too.
travisc
Are you using the pre-built exampel design or were there design modifications?
gcsimmonsjr
No modifications - just the example design. Pretty simple top level - version 2012.3: I/O declarations, signal declarations, IBUFDS instantiations for refclk0_i, refclk1_i, and sysclk_i, ibert_7series_gtx_0 instantiation.
roym
I'm afraid only the unmodified example design is supported.  It mostly doesn't work with modifications of any kind.
gcsimmonsjr
I just said that I DID NOT modify the example design.
(I just edited my earlier reply to more clearly reflect that.)
