Participant mowerj
jesd204b rx_core_clk ratio
My question is about the documentation's core_clk frequencies.  Why is the _core_clk frequency /66 in the JESD204 PHY v4.0 docs and /40 in JESD204 v7.2 docs?
tx_core_clkIn Core clock used to drive txusrclk and txuserclk2 of transceiver.Frequency = serial line rate/66
rx_core_clkIn Core clock used to drive rxusrclk and rxuserclk2 of transceiver.Frequency = serial line rate/66
rx_core_clkIn Core logic clock.Frequency = serial line rate/40
I was pretty confident that the PHY core needs to run at /40 also - hence the syncronous path between the two cores.
Re: jesd204b rx_core_clk ratio
Hi @mowerj ,
there are two entries for the clocks in pg198, one for JESD204C (/66) and one for JESD204B (/40). So, depending on the JESD version you get a different divider because a different encoding is used in the PHY.
Hi @mowerj ,
