why TX Serial Clock = Data Rate / 2 in GTX/GTH
How does the line rate doubled?
Re: why TX Serial Clock = Data Rate / 2 in GTX/GTH
transmitting & receiving data will be done with DDR.( Dual Data Rate )
can you expand upon your question please,
If the serial data rate is 10 Gb/s the serial clock does not equal 5 GHz.
Im taking a big guess here,
    If you think of a data rate of 10M bit per second, and draw it out, each bit is 100 ns wide,
          If that data was 1 0 1 0 1 0 1 0   and you draw it out,
             then as above each bit is true for 100 ns,
                 the period between two rising edges is 200 ns.
And 200 ns period is 5 MHz.
BUT, 5 Mhz is NOT the clock frequency, its the fundamental of the data,
    if you were to send a random stream of 1 and 0 out at 10 Mb/s, then you woud see on a spectrum analyser the fundamental at 5 MHz, and harmonics,   I leave that as a exerics for the reader to predict what frequencies the harmonics would be at ..
回复: why TX Serial Clock = Data Rate / 2 in GTX/GTH
hi @agilulf
tx serial data is updated on both rising edge and falling edge of the clock.
so clock frequency is line rate divided by 2.
Boris
