Observer vsureshkumar
Board design quiry...
Hello Sir,
           I am designing virtex-5 based board.I want to use  SPI PROM Flash and   BPI PROM Flash for storing configaration and user data respectively. Is it possible to connect both to bank 0(config bank) and use as mentioned above?.
Re: Board design quiry...
3.75 Gb/s if it is -3 or -2 speed grade V-5 device and 3.2 Gb/s for -1 speed grade device.
Scholar austin
v,
Read the configuration users guide.  It details all the possible configuration modes.  If yours isn't pictured, then it can not be done.
Austin Lesea
Principal Engineer
Xilinx San Jose
Instructor
Instructor
@vsureshkumar wrote:
Hello Sir,
I'm not clear on the question.  Are you saying that one flash only stores the FPGA bitstream and
another only stores user data?  In that configuration, the flash for user data could use any I/O's
compatible with the device.  It would not need to use dedicated configuration pins.
-- Gabor
yes my question is same, thank you........
Will it work if I connect GTP device MGT TX and RX pins  to GTX device MGT RX and TX pins? If yes any extra interface circuit is required? Will it work at GTP speed?
Yes, you can interface them directly.
What will be the speed ?
