codelani.80
Create Internal oscillator?
I would like to create an internal oscillator on Virtex-5 component? But there is no external oscillator. How I can do this?
Best Regards
tud_hartmann
STARTUP_VIRTEX5 has an output of the configuration internal oscillator (around 50 MHz). See page 104 of this document for more details: http://www.xilinx.com/support/documentation/user_guides/ug191.pdf
yashp
This is not possible.
Can you please give details about your query?
what you are actually trying to do here?
Yash
codelani.80
In my vhdl file, I have a process which needs clk signal. I would like to create internal clk signal by internal oscillator. Is there internal oscillator in xilinx library (Virtex-5 component)?
Best Regards
Nicolas
dwisehart
No, there is not. Your best source is an MMCM or PLL, which has to be driven from an external clock. Xilinx FPGA's need at least one (external) clock.
tud_hartmann
dwisehart
Yes, but the config clock can (and often does) go away after startup.  See your board design to find out.
