IBIS model for CML?
Hi community,
I am looking for an IBIS model for CML I/Os (especially CML13).
Search didn't help, sorry.
Greetings from Germany
Martin
Re: IBIS model for CML?
Moving to correct board.
Debraj
Scholar austin
m,
What device?  What family?  The transceiver GT models (IBIS-AMI) are in the lounges for each type, for each family (e.g. GTP, GTH, GTX, GTZ).
Austin Lesea
Principal Engineer
Xilinx San Jose
The CML IO standard only used for MGT TX &RX pins for Xilinx FPGA'S. The IBIS models does not give accurate simulation results in Giga Hz signal rates. So HSPICE or ELDO_AMI models are suitable for that range of frequencies.
Xilinx provides HSPICE or AMI models in website http://www.xilinx.com/support/download/index.htm. So you can use those models which provides all required simulation parameters for MGT pins.
Zynq
XC7Z100-2FFG900I4336
I found the models, but I can't download "Xilinx_Zynq_HSPICE-1.zip".
There is some kind of "About the download manager" tab opening in my browser, and that's it.
