Loading Multiple Xilinx(Spartan6) with same program from one Prom
Hello my case,
I need to load four spartan 6 with the same code. Can this be done from one prom? And what is the best way to go.
Thaks in advance for any response.
Hi @Dexterrd
Ganged Serial Configuration, User guide to refer (page no 147)
http://www.xilinx.com/support/documentation/user_guides/ug380.pdf
-Pratham
