tdienyon
Programming SPI PROM with user data via JTAG
Hi all,
I'm wondering if there is a way to program an EEPROM with user data using a JTAG cable, by including it along the JTAG chain (along with my V4 FPGA and respective Platform Flash)
The target EEPROM is an ST M25P80. I have my data in Intel HEX format and I want to try and program the EEPROM using JTAG. I'm reading the ML505 user guide, and it seems to suggest that you can do this (section 33, page 35), but doesnt elaborate as to how its done. Also, most of the other documentation I've read seems to suggest programming a .bit file for an FPGA, where as I'm trying to program in my own data.
Can an EEPROM be placed along the JTAG chain with other Xilinx devices and how can i use Impact to program it?
Dan
tdienyon
Does anyone have any ideas on this?
Dan
borisq
hi
check Add Data Files when you generate the spi programming file with iMPACT.
Boris.
tdienyon
Hi Boris,
When I try creating the SPI prom with"Add Data Files" ticked, it requests for a .mem or .elf file. What format are these and how can I insert my file which is in Intel Hex format?
Also, do you know how to physically connect the JTAG to the SPI lines? Will iMPACT detect the device?
Dan
Did you find the answer to your problem?
I've been trying to get Xilinx to tell me how to do something similar for the ML505 (I simply want to know how to program the platform flash on the board) but can't seem to get it working. I convert my .bit file to a .mcs file, then try to use the JTAG cable to program one of the platform flash devices... but it doesn't seem to work properly. I think I have the switches on the board set properly but hey maybe not...
I'd love to hear how your problem turned out so that I can use that experience to help me figure out what's going on...
tdienyon
No I havent found a solution yet. Something else cropped up so I havent had the time to look into this.
Anyone out there have any ideas on these issues??
Dan
vishwanath
Hi Dan,
          .mem and .elf are data files i mean to say software part of your project.if u need to download only software part of your project onto the flash you can go for adding .elf file.you can directly program hex file onto the flash. there are separate headers for JTAG as well as SPI connector and IMPACT does recognize the chain.
Vishwanath
vytautas
Hello.
I have yet read this discussion about SPI PROM and user data. What about possibility to store user data (but not in format like it's described in http://www.xilinx.com/support/documentation/application_notes/xapp694.pdf. I need to store .wav, .txt files) to SPI or other flash memory. Many projects are done using SystemACE, now I have board without CF reader, so that I need alternative solution. Mentioned files from SPI should be writen to DDR.
So, the question is how to store "my format" files into SPI?
Thank you!
Best Regards,
Vytautas
vytautas
Hello.
Does anybody  know how to solve this (to store user data in any format)?
Best Regards,
Vytautas
Anonymous
Not applicable
there are two switches that promgen can use either the -bd (which only allows elf or mem files) or -data_file which will allow any data format.  More details are under the promgen section in the command line tool users guide (http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_1/devref.pdf)
In the GUI (11.x and newer software, 10.1 and earlier had a slightly different GUI) when you are running through the wizard, you will have an option on step 3 (if you can for the prom you selected) that says "Add Non-configuration Data Files".  Pull down the drop down box to select yes.  Then when you are adding the data file select the drop down box that has the file type (ELF/MEM by default) and select "All files".  This should be using the -data_file switch to load in data in any format.
In 10.1 and earlier there should be a check box to add data files in the wizard.  Hopefully this clears up any confusion on this.
richard29
I have a similar problem: My device does not have a flash card reader so I am more or less dependent of using the SPI
for my design. I am playing a little bit around with partial reconfiguration and I have two partial bitstreams for on the fly reconfiguration. My idea was to put these two partial bitstreams into SPI, read them initially into RAM when the processor powers up and the ICAP module then reads the bitstreams with the appropriate offset from RAM whenever a reconfiguration occurs. Sounds all a bit comlicated but I can't think of any better solution. Am I on the right track or might there be a problem with putting two bitstreams into the SPI?
Many thanks
borisq
you can try -data_file option in PromGen command line.
Impact cannot detect the SPI, you must tell it.
the connection is like this.
download cable TDI - MOSI
cable TDO - MISO
TMS - CS
TCK - clock
refer to figure 2 of the following doc
http://www.xilinx.com/support/documentation/application_notes/xapp951.pdf
