Newbie max1
Prom XC17xx for LCA XC2018
i nedd some Prom XC1701 or other dimension for using with XC2018.Is ir possible to use some more newer and not hard to find  Prom?Possible in nNOT PLCC case but soic or DIL?
Instructor
Instructor
Re: Prom XC17xx for LCA XC2018
What's your power supply voltage?  If you're running these dinosaurs on +5V
you may not find too many "more recent" parts.  Most of the newer parts top
out at 3.3V
For 3.3V, you might find something close from Atmel if they still make the 17LVxx series.  Otherwise
if you don't need pin compatible your best bet is to use a XCF0xS "PlatformFlash" which is re-programmable
and much cheaper than the old 17xx parts.
Gabor
-- Gabor
Newbie max1
Many Thanks,
the problem is the supply: 5 volt.
The pin to pin compatibility isn't a problem.
Atmel make something at 5 volt?
Instructor
Instructor
It's not easy to find on the Atmel site.  Go to digikey.com and search
for "AT17LV".  Then click on Memory - FPGA Configuration.  Then you can
select just parts that can run on 5V.  There are a number of AT17LVxx parts
still available, including some in PLCC packages.  They are not cheap,
though so I wouldn't recommend it for a new design.  However I suspect
that using an ancient part like the XC2000 series would not be for a new
design.  They should be pin compatible with the original XC17xx parts
in the same package.
Gabor
-- Gabor
Newbie bmluis
hello,
I'm a Portuguese person,...
MAybe U can use the XC1736EPDG8C (5Volt) prom, it's not hard to find, and u can be buy it on RS components:
http://pt.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=xc1736
This RS vendor also has the XC1701PD8C 1Mx1b configuration prom
http://pt.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=XC1701
best regards.
Newbie iec598
xc2018-50pc68c
is this part programable or reprogramable
Newbie iec598
XC2018 ARE THESE DEVICES PROGRAMABLE OR REPROGRAMABLE
Instructor
Instructor
The XC2000 series was discontinued in 1996.  It was an early SRAM-based FPGA, so I would
say it's "infinitely reprogrammable."
However were you really asking if the XC17xx PROMs are re-programmable?  Those devices are
made with a UV-erasable EPROM process, so without a quartz window on the package they are one-time
programmable.
-- Gabor
-- Gabor
