Security in serial PROM XCF004S
We are using serial PROM XCF04S in our design, let me know how to enable the read sequrity to protect our IP.
Professor
Professor
Re: Security in serial PROM XCF004S
Yes, I was talking about the serial data between the PROM and the FPGA.  This port
is very simple and consists of a reset input, output enable input, clock input, and
data output.  Bits from the PROM come out in serial fashion.  There is no random access.
So looking at the D0/DIN pin of the FPGA you see the entire bitstream one bit at a time
starting from the beginning until the end with no swapping or gaps.  It doesn't take
very sophisticated instrumentation to capture this and store it.  So really the read
disable only makes copying the bitstream a little bit harder and only prevents
copying by people who are not going to go to the extra effort to open the box and
atach a couple of wires.  It's a little bit like putting a double lock on the front door
but leaving a window open.  The question you need to answer is who are you trying
to prevent from copying your IP, and how much effort are they willing to put into
copying it anyway?  If it is just to "keep honest people honest" by not giving them
the easy readback through the programming connector, then you're O.K.  But
if you're trying to secure your IP from copying by people who have serious intent
to steal it, then you need something better to protect it.
Gabor
-- Gabor
XCFxxS does not provide read protection. Only the XCFP series does.
 I Referred “DS123 (v2.5) October 18, 2004   Platform Flash In-System Programmable Configuration PROMS” document page 4 says as like below
Design Security
The Xilinx in-system programmable Platform Flash PROMdevices incorporate advanced data security features to fully
protect the FPGA programming data against unauthorizedreading via JTAG. The XCFxxP PROMs can also be programmedto prevent inadvertent writing via JTAG. Table 4and Table 5 show the security settings available for the
XCFxxS PROM and XCFxxP PROM, respectively.
Read ProtectionThe read protect security bit can be set by the user to preventthe internal programming pattern from being read orcopied via JTAG. Read protection does not prevent writeoperations. For the XCFxxS PROM, the read protect securitybit is set for the entire device, and resetting the read protectsecurity bit requires erasing the entire device. For theXCFxxP PROM the read protect security bit can be set forindividual design revisions, and resetting the read protectbit requires erasing the particular design revision.
Please let me conform
Professor
Professor
"read security" is not very secure.  It only prevents readback from the JTAG port,
but the entire contents of the PROM are available via the configuration port.  So
anyone with access to the hardware can read the data anyway.  In fact, on a serial
device you can capture the data stream during device configuration using just
two wires to pick up CCLK and DIN.  So the only real security you can have with
XCFxxS parts is if you use bitstream encryption.
-- Gabor
If I remember correctly, you can check the Read Protect in Device Programming Properties Dialog Box.
Refer to the following link.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/pim_db_programming_properties.htm
what you ment by configuration port. Is it the configuration between FPGA and PROM for data transfer?
Professor
Professor
Gabor
-- Gabor
Thanks for the replay. I got solution to my question, i will think on different option to protect my IP.
Basamma yb
how I  can   put     Fpga  ID  code in      programing  mcs  file
I want   to    use  my  program  file   only  for   uniqe   FPGA  whit  special  ID
it  is  not important   for me which   some one be  able to read  my     desigen   file  on    the   on  borad xilinx flash
I just    want   ,  this file      work only  wiht     FPGA   that  has    specifiec ID
Hello
IF i am using xc6slx9-2tqg144c we can not use bitstream encryption.what will we do to protect or secure my Flash DATA?
Professor
Professor
Please start a new thread for this topic.
-- Gabor
