Participant heiyux
Two questions about BPI configration
Hi everybody,
     I‘m about to use BPI configration for V6 FPGA, LX240T, and running into two questions.
     I use  S29GL01GP as the BPI flash.
Q1: I was told to float CCLK pin for BPI configration in UG360 page 52 & page 53,
       but I also found another guidance in UG438 page34 & page35 Note 3, which shows to
       connect the CCLK to the BPI Flash's Clock pin. Which should I follow?
Q2: When using XCF128X & Virtex 6, IO_L18P_24 should be connected to the L# pin of the
       Flash for indirect programming purpose. What should I do if I use third part Flash, such
      as S29GL01GP?
P.S. I found there is few guide for BPI configration using third part Flash. Is there any?
      Oh, sorry, it turned out a question No.3. :)
Thank you very much!
Day.
