Visitor engrjet
Virtex6 Configuration Problem
I am using V6LX130T with XCF128 . Generally everything works fine. Platform flash is getting programmed and FPGA is getting configured normally.
But when I start in the morning after power on FPGA not getting configured though the PFLASH is already programmed with the mcs.
My observations:
When started for the first time in a day FPGA is not configured.
Then I waited for few minutes sometimes it comes up.
Sometimes after waiting for few minutes if turned off and on again then it comes up.
Once started, For the whole day I could turn off and on as many times I wanted and everytime FPGA got successfully configured.
I am unable to understand what is the root cause for not getting configured when I try for the first time. Need Help
Thanks in advance
Visitor engrjet
Re: Virtex6 Configuration Problem
I am still not out of this problem. Need somebodys help.
Teacher eteam00
Some things to check:
  • XCF128 purchased from unreliable channel
  • defective XCF128, or some other component (try another board, check for consistency)
  • marginal power supply or supplies
  • marginal board layout design (poor signal integrity in XCF128 interface signals)
  • configuration settings of FPGA or XCF128 deviate from UG360 recommendations
  • state of INIT_B and DONE pins when configuration fails
-- Bob Elkind
SIGNATURE:
Summary:
I'm wondering if the issue is resolved or not.
Can you please read the status register of the device after the configuration failure? This will give us a clue on what exactly is going wrong.
Krishna
