Visitor tjb0318
XC18V02VQG44C programming failed
iMPACT reports "Programming Failed when I use a Platform Cable USB to program a XC18V02 with "VQG44AEN1335" letter code located on the package topmark.
but when I  use a Platform Cable USB to program a XC18V02 with "VQG44BTT" letter code located on the package topmark, IMPACT reports "Programming successfully.
Could you tell me how to solve this problem, if the "1335" in the "VQG44AEN1335" letter code located on the package topmark represents datecode,and if the devices that"AEN" is marked on the package topmark is discontinued from March 1, 2005
Re: XC18V02VQG44C programming failed
What version of ISE tools are you using? Please check whether that ISE tools support 18V02VQG44C or not
Check the following AR it might help you
http://www.xilinx.com/support/answers/21503.htm
Krishna
Visitor tjb0318
The Revision of  ISE tools is  12.3,It should be support 18V02VQG44C,if the cause of  question is the difference "AEN"and "BTT"
