Visitor krclemens
XC3000 Series FPGA
Good Morning,
I have been searching for a compatible replacement for the XC3195-5 FPGA.
It can have more pins, be in a different package, and if need be, I could work with lower voltage.
I do need an industrial grade IC though.
Could anybody help? I've also attached the datasheet for the XC3000 Series FPGA
Thanks in advance,
Ken
Teacher eteam00
Re: XC3195 FPGA replacement
I would suggest trying to port your design to one of the 5V-tolerant CPLD devices.  The CoolRunner XPLA3 XCR3000 family is 3.3V logic with 5V tolerant inputs.  The largest in this device family, the XCR3512XL, is roughly equivalent to the "logic density" of the XC3195 FPGA.  While the 'logic density' may be similar, the CPLD has 512 registers, a small fraction of the number of registers available in the XC3195.
You will want to convert your schematics to HDL code, either VHDL or Verilog.  Any asynchronous timing paths or logic will need to be re-implemented.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher eteam00
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
Re: XC3000 Series FPGA
Which package were you working with?  Since there are no recent FPGA's smaller
than the 3195 as far as fabric LUT / flip-flop count, you really only need to look for
a part that has at least as many I/O's as you need.
Also you say it can work with lower voltage (all newer parts do), but what about I/O
voltages.  Do you need 5V logic tolerance on the I/O?  Newer parts are typically
not 5V tolerant.  The last ones I'm aware of are Spartan 2 (not 2e), but that is already
at end-of-life status.  You can still get them, but not for long, so unless this is a
temporary fix pending a total redesign I would not suggest it.
Depending on what you originally used the part for, you might also consider a large
CPLD instead of an FPGA.
-- Gabor
-- Gabor
Visitor krclemens
Good Morning Eteam00,
Thank you for your advice on the FPGA, I appreciate your help.
I researched both components and submitted the necessary requirements.
Visitor krclemens
Good Morning Gabor,
The package I currently have is a PG175. I can work with other packages, as it's just a matter of making an adapter board.
We would definately need 5V tolerant inputs, and we would also need to build level shifters for the outputs.
I have been looking into the CPLD's. I think if we go ahead with the modification, that is what we will use.
Thanks again for your help.
Ken
Newbie punithaj
i am using XC3090A-7PG175 in one of my design, as this is absolute i want to know the alternate for the same.
Newbie addermaster
Please let me know if you got something about alternative, as I'am also intrested.
