Visitor engrjet
XCF128 Programming Failed
Platform Flash is not getting programmed. I am using V6LX195T.
Following message had been logged.
INFO:iMPACT - Current time: 31-07-2012 10:31:15
// *** BATCH CMD : Program -p 1 -dataWidth 16 -rs1 NONE -rs0 NONE -bpionly -e -v -loadfpga
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading:   35.12 C, Min. Reading:   31.67 C, Max. Reading:   37.58 C
1: VCCINT Supply: Current Reading:   0.993 V, Min. Reading:   0.981 V, Max. Reading:   1.002 V
1: VCCAUX Supply: Current Reading:   2.505 V, Min. Reading:   2.481 V, Max. Reading:   2.525 V
'1': BPI access core not detected. BPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/13.1/ISE_DS/ISE/virtex6/data/xc6vlx195t_jbpi.cor.
'1': Downloading core...
 Match_cycle = NoWait.
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1111 0101 1110 0000 1011 1100 1000
INFO:iMPACT:2492 - '1': Completed downloading core to device.
Current cable speed is set to 6.000 Mhz.
Cable speed is default to 3Mhz or lower for BPI operations.
Current cable speed is set to 3.000 Mhz.
Setting Flash Control Pins ...
Setting Configuration Register ...
Populating BPI common flash interface ...
Common Flash Interface Information Query completed successfully.
INFO:iMPACT - Common Flash Interface Information from Device:
INFO:iMPACT - Verification string:     51 52 59
INFO:iMPACT - Manufacturer ID:         49
INFO:iMPACT - Vendor ID:               01
INFO:iMPACT - Device Code:             18
Using x16 mode ...
'1': Erasing device...
'1': Start address = 0x00000000, End address = 0x0075670B.
done.
'1': Erasure completed successfully.
Using x16 mode ...
INFO:iMPACT - Using Word Programming.
'1': Programming Flash.
done.
'1': Flash Programming completed successfully.
Using x16 mode ...
'1': Reading device contents...
Failed at address, 0.
'1': Verification Terminated.
INFO:iMPACT - '1': Flash was not programed successfully.
PROGRESS_END - End Operation.
Elapsed time =    571 sec.
My observations:
1. Erasing the flash was succesful
2. Blank check was also successful
3. Programming failed.
4. Then I tried Blank check , but it failed.
5. Read back the mcs after programming. It contains all FFs.
I could not think of a reason. Need help urgently..
Thanks in advance
Teacher eteam00
Re: XCF128 Programming Failed
Are you using a standard developement board, or is this a custom board design?
If custom board design, have you tested multiple copies of this board?
Is the fault inconsistent, somewhat consistent, or completely repeatable?
You might find it helpful to post your schematics for the board.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor engrjet
Thanks for your reply.
I use a custom board and have multiple boards. This problem is occuring in only one of those boards.
I can assure the schematic is correct.I am using Master Select Map for configuration mode.
I have observed that the Write signal is pulsing after program command is issued in impact.
Another may be critical observation found that when PFLASH programming is about 6% the FPGA DONE LED starts glowing.
Hope You can guide me to find out the fault.
Teacher eteam00
I use a custom board and have multiple boards. This problem is occuring in only one of those boards. I can assure the schematic is correct.
The obvious conclusions are that your schematic is correct, your board design is correct -- and you have an assembly, board fab, or component failure causing one board to fail.  Assembly errors (shorts, opens, misaligned parts) are statistically much more common than component failures.
I have no great insight for you, other than to encourage you to do all the tedious hunting and pecking to find the problem.
Have you checked power supplies for transient faults -- with an oscilloscope -- when programming the PFLASH?
When programming PFLASH through iMPACT, the FPGA's DONE status should not be changing.  What waveform do you see on the FPGA DONE output?
Having the working boards available for direct comparison on a signal-by-signal basis should be a great debugging help to you.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor engrjet
Thanks for your Reply.
FPGA DONE is not a problem. As impact downloads the core for indirect programming, DONE going low is indication of FPGA configured with the core. rest I'll try all the tedious debugging procedure.
thanks
Teacher eteam00
FPGA DONE going high indicates that the FPGA is configured with the core for indirect programming.
-- Bob Elkind
SIGNATURE:
Summary:
